- Dec 28, 2001
- Corner of No and Where
I use very small stranded wire- I think it's 24ga, but I 'm not sure.
The way I did it: tin the wires, then tin the mosfets.
Hold the wire on the mosfet and put the iron tip right in there!! A bit scary because my tip is too big so when its in the right spot I can't see it
I held it for 5 or 6 seconds, and pulled the iron out....then gently tugged the wire: I had to redo a couple of wires out of the boards I did.
Had to run shrink tubing down the wires after since I melted so much insulation off
