- Jul 3, 2013
Hello, Im new to this site/forum.
I joined in, and created this forum, because I'm about to build a PC Desktop for the first time. I've put alot of time into learning the basics of building your own computer, the parts & how to mount it all together, but some questions remains.
Maybe someone could help me answer those frustrating questions
I actually have a lot... i think I'm one of these persons who just feel a need to understand everything
I'm mainly gonna use the computer for 2 things:
1) Gaming, games like: League of Legends, Minecraft & MW3.
2) Video/Photo editing, with programs like: After effects, Photoshop & Premiere Pro.
My budget is around 1600$, but that info doesn't have anything to do with my questions i think.
I don't have any precise specs of what I'm gonna buy, since i haven't decided yet.
Should be something like 16gb ram, Intel i7 gen. 4, GTX670 NVIDIA & a 250gb SSD + 1TB HDD. I dont know anything about graphic cards, so GTX670 is kind of random choice.
Questions:
1)
When i search for the 8 components (CPU, GPU, RAM, Power, Case, MB, DVD Reader, Harddrive) How do i check if all of the parts "fit together" so i don't end up with a scenario like my cpu not fitting the MB, and not enough power from my powersupply?
And how the MB & also things like GPU will fit the case I'm building it in?
2)
I told u what I'm going to be using the computer for, and i came across someone talking about SLI ( 2 graphic cards i suppose)
For the games I'm playing, and the video editing software I'll be using, is it necessary to have 2 graphic cards? And is it true, that SLI only boosts your FPS In game, and not really effects anything else when using the computer other then gaming?
3)
Iv'e read something about overclocking. Its like asking a machine to deliver something its not designed for, and therefor might crash, right? Do i have to worry about my computer crashing, if i build my pc myself and don't manually try to overclock it, but just run it as it is? The last thing i wont, is to fry the new expensive hardware i pick out from the store, so how do i avoid that, and stay safe ?
4)
I asume most motherboards are already equipped with a soundcard? Are they ok quality, or should i buy a motherboard without, and buy a soundcard to install thats better?
5)
If I'm going to do the things i mentioned with my computer, should i then buy a better cooler for my CPU Processor (gonna be a Intel 7 gen. 4 probably) or is it fine to just use the one that comes with the CPU in the package?
6)
Does all Motherboards support 2 hard-drives, or do i have to look out for a speciel one, that can do 250gb SSD & a 1TB HDD?
7)
I know very little about graphic cards, what kind of cards would suite my needs? I have no idea of what "GTX670 NVIDIA" Means
8)
Is it necessary / a good idea, to buy cooling for your ram?
9) Is Ram really just RAM? I mean, can 16gb (2x8) Ram be different quality, if so, what should i buy?
Thats about all, Sorry for my bad english and sorry if I'm writing too much, i tried to keep it short. Any help would be much appreciated Even answering just 1 of my questions would be a big help!!
Questions:
1)
2)
3)
4)
5)
6)
7)
8)
