They load up faster. Really what to put on the SSD is your decision, whatever you want to load faster should be there.
....What do u think, any improvements i should need, plz tell me!
everything look ok, although i think 1tb is a little small for movie.
As for the 16GB RAM, are you really sure you would need them? I upgraded to 16GB RAM (I use after effects, too) and it gave me a mere performance boost of about 0.5%-1% in Render time. If you have the money and like to spend it, go for it. If you like to keep it on budget, even for AE 8GB is plenty.
That depends on when later is, I'd always go 2x2GB, 2x4Gb, 2x8GB. If you would wait months for the other 8 GB stick, go 2x4GB now, and add 2x4GB later. If you really 16GB though.Or will It be better to buy 1 single 8gb stick, and buy another stick later?
My CPU never gets above 33c and VRM above 39c under maximum load and stress tests.
To me, more clutter and a huge monstrosity hanging off the motherboard equals less air flow, and when you can visually see every part of your motherboard (except where GPUs are mounted, you tend to have better air flow across the motherboard, which equals better cooling, similar to configurations involving water loops from blocks, which provide lower temps, not higher, and only in this case its an AIO which doesn't require routine flushing.
Also the heat that is dissipated off the radiator from the CPU cooler gets exhausted immediately from a push / pull configuration at the rear of the case, as opposed to having all that heat recirculated inside the case in a vortex.
solid temps... Proves nothing though unless you tested with an air cooler too and temps were higher.My CPU never gets above 33c and VRM above 39c under maximum load and stress tests.
The major flaw with the AIOs is not performance, it's shoddy build quality. Other than the Swiftech H220, they all pretty much use low quality pumps which have a rather high failure rate. Of course "high" in the PC world is probably around 8-10%, so for the majority, they work fine, but it's still easier to avoid them and stick to air unless you have a very hot running CPU where that extra bit of performance is necessary.
