- Oct 4, 2013
First post!
My story:
I recently decided that I was going to try building a budget server out of components from years gone by. It was to be a high end computer from around 2009 and it was to cost under $100 all in. Pretty optomistic budget, I know.
I picked up two L5410 xeons and 8GB of ram for $20 bucks at an electronics recycler.
Got a Supermicro X7DWN+ motherboard on ebay for $30.
Fancy shmancy 1200w power supply for $10.
Things were good until I started assembly.
Everything was going in a case I already owned. An Antec somethingorother full tower.
The motherboard is not a standard ATX mobo. Its some fancy Enhanced Extended ATX that Supermicro invented. Not only would it not fit, I couldn't get it inside the case because of all the brackets for HDDs. So I took off the back panel, cut out the motherboard plate, fashioned a custom plate, cut off some of the drive bay area, and riveted the motherboard in place. Take that roadblock.
So I excitedly power it on for the first time. Everything is going great. I'm browsing through the BIOS options when I hear a piercing shriek from the motherboard, a non-stop scream of pain. I check in the BIOS and sure enough... its overheating.
I should have anticipated this. The MoBo is clearly from a rack-mount system. The heatsinks are passive, and it probably used to have a hurricane pushed through it.
I managed to put some fans in place that get the system to idle at around 60-65 but I can easily push it up to 80 by running torture tests. This is bad, it needs better cooling.
I have considered attempting to modify the passive fans to be active, but that would be rather difficult. I don't really want to buy two new LGA771 heatsinks because that would put me over budget and who ever heard of the most expensive component in a system being the heatsinks?! There are two more spaces for fans that are unpopulated and I plan on putting some fans in, but I dont think they will affect the processors so much.
TL;DR
I built a cheap computer system and it runs too hot... idea me to cool it cheaply.
Some pics of the build...
Ouch... tight fit...
My story:
TL;DR
