Aha, that's what I was guessing, but I wasn't positive.
So should I change it back to 5,5,5,15 or keep it @ 4,4,4,12?
I want the way that will give me best performance for how I have it set (800 1:1)
I suppose if I changed it back I could decrease those voltages and get a bit less heat, but heat does seem fine.
Incidentally I dropped down the CPU clock last night to 3.4 w/ 400 fsb @ x8+.5. I did not like those temps passing 75 like they had been at 3.8, and I don't want to chance damage...I know my cpu cooler is not the greatest. In doing that I was able to drop the core voltage as well, to 1 or 2 notches below the stock recommendation. With it set like that, and the RAM voltages slightly bumped my loead temps (in real temp) are mind-upper 30's, and mid-upper 50's-low 60's in prime...
The truth is I don't do much gaming, so I don't need the cpu as blazing fast as is possible. I think 3.4 is gonna be plenty fast for me. I would like to get things perfect though, with the votlages, and the RAM set the best it can be for most performance...and of course temps as low as possible.
