hey all.
umm..have current rig at mo
celeron d 325 running @ 3.42ghz @ stock volts @ 180FSB @37C full load using an SLK-947U with a panaflo 92mm H1A.
the ram im using (which ive got a good idea is the bottleneck in the overclock) is 2 different speed dimms.
the first is a Twinmos 512MB pc2100 Dimm rated at 2.2.2.5 @100Mhz and 2.5.3.3.6 @133mhz. the second dimm is a Vdata PC3200 rated at 3.4.4.8 @ 200mhz.
i've got BOTH sticks running without any extra voltage or anything at 2.5.3.3.6@180mhz. i KNOW that the pc3200 can manage 218mhz @ 2.5.3.3.6, but not too sure about the twinmos.
i've got the opportunity to 'acquire' 2x512mb pc3200 Buffalo tech dimms, which are rated at 3.3.3.6 @200mhz and have done 230mhz at those timings without any extra volts.
now im running a MSI 865PE neo2 PFISR board.
would it be worthwhile actually getting this buffalo tech ram?
im kinda aiming for around the 4ghz mark, the chip has infact booted at 3.8ghz, and im gna try it again in a minute, but i had to take out the twinmos ram and up the voltage too a little but was afraid of taking it too high.
what would be a safe voltage to take the chip to? it is a prescott core so AFAIK it shouldnt really suffer from that SNDS (or something like that) the detirioration should it?
just wanna see what i can squeeze from this machine before i get a hold of a 2.8c. the machine itself is used mainly for word typing, excel, and a helluva lotta we browsing.
what would be my best option?
im running the case without the side panel on too, and thats how ive managed to get it down to 37C at full load.
thanx.
thanx.
