So lets say I got two of the Alphacool 280 rads--would the PMP-450 handle that, or would I need to buy a second?
Edit: Not to stack, but to place somewhere else in the case.
Thanks m0r7if3r not having owned or tested that radiator it's tough for me to give an exact figure to the OP. I just wanted to make sure he was ok with the decision to go with that size rad. I usually go overkill on the raddage if I want the system to be quiet. It also depends on how much gaming stresses the Dual Gpus!Those numbers look like they're running low to me, and based on the v2 rad testing setup that martin is using, I think that his enclosure is a bit restrictive and is limiting airflow through the rad. I think it would be safe to say that the numbers you gave are a worst case scenario, and don't represent typical use that should be designed for. That said, I'm still getting back into it, data wise, so I might be way off.
m0r7if3r, Here's another set of pretty comprehensive testing on the alphacool rads:
http://www.coolingtechnique.com/en-...m-and-360mm-full-copper-review.html?showall=1
Mandrake: I didn't realize that the delta refers to just the water temp. I guess I don't really know what to do with that information--how that relates to the cooling capacity of a radiator. Obviously I understand lower deltas mean better performance and lower GPU temps, but what are those GPU temps? Why is everyone choosing delta 10 as the magic minimum number that everyone is attempting to obtain?
m0r7if3r, I have looked at the DDC's however I have heard they are nosier, and having a quiet system is the ultimate goal of this build. However, and this is an interesting idea, I did find this Alphacool SilentBox for DDC pumps. I just don't know how well they work.
As long as you've considered them and made an educated choice I would never fault someone for using a D5...I ask the same question the other way around when people come through having picked a DDC . I can't offer any insight into the effectiveness of the silentbox, sorry.
I've never heard of DDCs or D5s leaking. Tops are basically worthless for the D5, but they're a great investment for DDCs
Very good point's Jack!Well, I personally like the Corsair Air 540 because its newer than the fractal by design, way more room and way better air flow. The good thing about the Air 540 is it was made for both hardcore air cooling or custom watercooling. I've seen guys with 2 hot premium GPUs + CPU in that case running 24/7 with a triple radiator in front and dual up top. That's all it fits and all you need. I honestly would wait on the water cooling and just grab the Air 540. I almost forgot, I bet you your temps will get less with the increase of air flow from that new case which would possibly result in lower noise levels till you get enough funds to go all out on water cooling. I always advise people that want to jump into water cooling, its the easiest and always the best way to think about the case first and which to buy incase they choose down the road to jump into watercooling. More cases nowadays by design are becoming water cooling ready.
I also should add, I am not sure if its a good idea water cooling those 270 GPU(s). Don't think its worth the money spend on water cooling low end GPUs. Correct me if I am wrong but aren't the 270s basically 760s? Usually if you get a mid-end to high-end GPU(s) is than worth the added cost of water cooling. This just justifies it more to just get a better airflow case like the 540. Again, its all up to you.
