hi every1 gotta little problem. ireplaced my laptop cpu a pavilion zd7000 series notebook.
I use to have a 3.06 cpu in there and it died out baught a new one P4 3.06 533fsb/512k
and now when i right click on my computer ---- properties , in system properties under general it says:
genuine
intel ® CPU 3.06
1.6 ghz
512 mb of ram
My question is wy does it say 1.6 if I have a 3.06 it does not show on my brothers laptop.
I have updated the bios
Then iwent into bios to maybe change some settings in there but nothing can be changed and in the bios it alsoo says 1.6 for some reason
I talked to the person who sold me the CPU and he sent me a mail:
it's a mobile CPU, you have to set it to max performance in order for it to run at 3.06
can any1 help me out plz or knows how to set it's max performance...cause in bios i can't chnage anything it's like you can only change the date and time
I DID SOME TEST WITH EVEREST AND PRIME95 ALSOO IN POWER MANAGEMEN I HAVE SET IT TO MAX BATTERY.
IS THIS A WRONG CPU FOR MY LAPTOP OR WHAT IT IS A PAVILION ZD7000
HERE ARE THE RESULTS FROM EVEREST WHILE RUNNING PRIME95
this is what i got in the cpu test with everest while running prime 95
Field Value
CPU Properties
CPU Type Mobile Intel Pentium 4
CPU Alias Northwood, A80532
Engineering Sample No
CPUID CPU Name Genuine Intel® CPU 3.06GHz
CPUID Revision 00000F29h
CPU Speed
CPU Clock 1597.13 MHz (original: 3066 MHz)
CPU Multiplier 12.0x
CPU FSB 132.93 MHz (original: 133 MHz)
Memory Bus 166.16 MHz
CPU Cache
L1 Trace Cache 12K Instructions
L1 Data Cache 8 KB
L2 Cache 512 KB (On-Die, ECC, ATC, Full-Speed)
Motherboard Properties
Motherboard ID <DMI>
Motherboard Name Hewlett-Packard Pavilion zd7000 (DM790A#ABA)
Chipset Properties
Motherboard Chipset Intel Springdale i865PE
Memory Timings 2.5-3-3-7 (CL-RCD-RP-RAS)
PAT Enabled
SPD Memory Modules
DIMM1: Infineon 64D32020GDL6B 256 MB PC2700 DDR SDRAM (2.5-3-3-7 @ 166 MHz) (2.0-3-3-6 @ 133 MHz)
DIMM3: Hyundai HYMD232M646C6-J 256 MB PC2700 DDR SDRAM (2.5-3-3-7 @ 166 MHz) (2.0-3-3-6 @ 133 MHz)
BIOS Properties
System BIOS Date 10/14/04
Video BIOS Date 08/27/03
DMI BIOS Version F.35
Graphics Processor Properties
Video Adapter nVIDIA GeForce FX Go5600 (HP)
GPU Code Name NV31M (AGP 8x 10DE / 031A, Rev A1)
GPU Clock 276 MHz
Memory Clock 301 MHz
it would never go over 1.597
genuine
intel ® CPU 3.06
1.6 ghz
512 mb of ram
Field Value
CPU Properties
CPU Speed
CPU Cache
L1 Data Cache 8 KB
Chipset Properties
PAT Enabled
SPD Memory Modules
BIOS Properties
GPU Clock 276 MHz
