- Feb 13, 2012
HI,
Specs
Asus p8z68 v pro
2600k @ 4.4ghz 1.310v
A70 push/pull
corsair vengance @ 1600mhz
1TB hitachi x2 raid0
power cool 80+ 650w modular psu
gtx 560 ti o.c
antec 902 v3 case
Ok here it is, im trying to set my bios settings manually to try lower the cpu volts a little as im hitting 71.c under load and i use my pc nearly 24/7 for work and gaming. everything is set to auto apart from RAM which is set at 1600mhz 1.5v load line is set to extreme and cpu volt to 1.310v.
im pretty new to overclocking the sandy bridges and read through a few guides but having no luck lowering the volts and getting stable. at the moment i can run prime95 all modes for a good 15 hours stable pass superPI 32 and intel burn test all run stable. im sure my chip can run at lower voltages and getting the temps down 5.c or more would be great so if anyone has had some experience with this setup id be grateful for some help.
thanks.
Specs
Asus p8z68 v pro
A70 push/pull
gtx 560 ti o.c
antec 902 v3 case
thanks.
