- Apr 26, 2012
- New York, USA
I did a thorough cleaning of my sig system today, and after putting it all back together, I ran Prime 95 to give the new TIM a quick burn, and it locked up almost instantly.
So, I started messing with settings, and this is what I have so far;
CPU Freq. = 240
Multi = 17
VCore = 1.450, up from 1.385
NB Freq = 2400
NB Voltage = 1.1250, up from 1.1125
HT Bus = 1920
LLC = Enabled (options are enabled, disabled, off)
Temperature under load after 10 minutes was 57C at the socket, and 32C at the cores. I can't seem to manage to get it to run any longer. Do I need to up the voltage more? It seems like a hefty bump, especially since I've almost added 1/10 of a volt to my previously stable overclock. If I can get a screen shot of my next P95 run, I'll post it.
CPU Freq. = 240
Multi = 17
NB Freq = 2400
HT Bus = 1920
