- Jan 10, 2012
not so much worried as concerned as it gets close to 72c, the limit we, as a rule stick to.
do you have fans in the case side window blowing in?
if not, make that happen.
if that will not happen, lock the two cores.
as a rule we follow Mr. Trents path. 4.0 ghz max, 55c (24/7 clock) core temp with a peak of 62c, 72c socket temp. these limits keep us from frying your stuff.
if you want to puhh higher after you know what you are doing start another thread stating you want to push for a moonshot at all costs and folks will help you with that.
we are about overclocking after all and when overclocking you toast stuff.
