- Thread Starter
- #21
Can you push the core any higher?
I noticed that my cpu cooler is never running above 1900 RPM, even though the specs it should operate from 900-2500RPM.
Perhaps its the Cool'n'Quiet feature that doesnt consider the CPU to be hot enough for the fan to operate at full speed?
Your cooler's fan is programmed to run faster as temps rise. However, the calibration of such may not match the particular application need very well. I wonder if there is a way to make it more aggressive. Is it a PWM type fan? How many pins? With PWM (pulse width modulation) fans you can use Speedfan to control the speed.
If you're overclocking it is always recommended that you disable Cool N Quiet, C1E and any other "green" throttle down features. They cause both confusion and (at higher overclocks) instability.
Yes, that 1.2 in AMDOverdrive is with regard to the CPUNB voltage.
AMDOverdrive is handy for determining what the stock voltage settings are for various overclocking parameters but we don't recommend it for overclocking per se. AMDOverdrive does not give reliable readouts when things have been manually overclocked in bios. So if you use it to determine stock settings, make sure everything is on Auto first.
1.2v is correct for the cpuNB (not chipset) voltage. The reason we set the voltages and other things manually is to make sure Auto doesn't change them as we change other values, like the HTRef.
For now you should set manual values and turn off CoolNQuiet, C1E (yes, AMDs use that but your board may not have it), and SmartFan (or Q-Fan, depending on your board). I understand it's good to idle down to save power but when you're trying to OC it just gets in the way. After you figure out your OC you can go back and re-enable that stuff if you want.
Edit:
I'd continue running the 667 RAM timings and speed with a slight bump in vDIMM as trents suggested earlier (1.55v should work good). RAM speed and timings is something else you can adjust later. For now the CPU and cpuNB are the important things to work on. In the race for system performance the CPU is #1 and the cpuNB is second but is often needed for stability for higher CPU speeds. RAM is a distant third and the HT Link is so far back it almost doesn't count ...
wanner,
Concerning temps and coolers, to give you some reference point: Your CPU and my CPU (Athlon II X4) are both rated at 95W at stock speed and voltages. With your CPU overclocked to 3.33 from a stock 3.0 and running at 1.376v, you are getting max core temps of 54C after 10 min. of Prime. Add about 2C for a longer run. That's with your Freezer Pro 7.
On my system with a Thermalright Ultra 120 Extreme and a push-pull fan setup with the fans only running about 1500-1600 rpm, and my CPU overclocked from 2.8 to 3.5 on 1.456 vcore, my max core temps during a 1 hr. Prime run are low 40s C at 21C ambient. Oh, I also have 5 case fans (including a top fan because my rev. 1 TRUE points to the top of the case).
That might put the question of the value of a better cooler in perspective.
I removed the case side plate and opened one of the casefanholes at the top. Been running prime95 for 10min now @ 3.3GHZ and core temps at 48-49 degrees.
The only way to know for sure is to plug the CPU fan directly into the PSU ...When i disable smart cpu fan in bios the fan should go at max rpm, however it doesnt go above 1800-1900RPM. As i mentioned earlier the specs says that it operates between 900-2500RPM. And according to this article: http://www.silentpcreview.com/article285-page4.html at 12V the fan operates at maximum. Is it possible that my motherboard is somehow feeding it too little juice? I have connected the 4pin connector of the fan to the CPU_FAN on the motherboard...
Sell the Freezer Pro 7 through an online auction.
Only thing that concerns me is the size of the mugen.
Does your ram have tall heat spreaders that might interfere with the Muygen 2 or do you have a huge NB/IGP cooler?
