yes .... 1.45n for 1.8GHZ Northbridge is up around 2500MHZ @ 1.265v and HT 2300 MHZ ram 1866 @ 9 9 9 24 @ 1.675v I think. Turned out all it needed for the next step was more VCore.
I am currently testing @5006MHZ stable for 30 min though it took me a bit of VCore to do that now sitting at 1.524v. Core temps ar 54*C and Socket Temp is 57*C with an ambient of 19*C right now ...... have the window open. Even after all my prime runs my computer has only heated up this room 3*C over the last 5 or so hours which would not have been possible with the FX 8150.
Might be to early to prove this but it is something to keep an eye on but my settings for 4.8GHZ was almost the same as I had for my FX 8150 @ 4.7GHZ. I took some snaps of my BIOS before flashing to the newest Bios for my board, I'll have to take a look after when I get the chance and compare them.
(Edit)
Dam ..... spoke to soon ..... ILLEGAL SUM OUT @ 30.5min.
Man, I can't even OC mine -.- comp freezes every time I run prime ( on any settings ). Its not the chip coz I could prime on stock or the motherboard since I oc'd my 1100t before. Did you tweak all the settings ? would you mind walking me thru all the steps ? thanks.
