Well looks like I have an extended holliday ..... truck broke down.
OCing is not about settings .... what will work for me might not work for you its all about finding what will work for you. What I am siggesting and what I feel works best when pushing your OC a bit more on these FX CPUs is to use a combination of the FSB and a multiplier to help get stable.
Correct me if I am wrong but you are stable @ 4.6GHZ .... right.
What I am suggesting is set your FSB to 225 and a multi @ 20.5 and test for stability. You will need to check and back off some settings at the same time ..... Your ram, CPU/NB and HT Link will all be raised as you do this, bring them back down to something near or below what you have them at now @ 4.6GHZ. What worked for me with a 225 FSB was CPU/NB and HT around 2350 ish ..... can't remember exactly but you will see the numbers when you click on the setting in bios look for something in the 2300 - 2400MHZ area and it wont hurt to go lower we can always bump them up later and keep both the CPU/NB and HT the same. My system would not boot at annything over 2500MHZ on the CPU/NB.
This is just a different way to get your 4.6GHZ clock you have now. If this is still stable then post back your results. Lets get you stable there first and worry about 4.8 later. I am gonna be home all day today though I have lots of work to do around the house and will keep an eye out for yur progress.
I raised the volts all the way to 4.3 and my llc takes it up to 4.8 and still does nothing. Temps are reaching 62 degrees on cores and 64 on cpu.
Your welcome. The good thing in all this is you have worked at and learnd 2 different ways to OC your FX CPU. They are a pretty good CPU but do draw a bit of pwer and gen a lot of heat / fair amount of heat, dealing with the heat is the hard part. One question though .......
I am gonna asume 4.3 and 4.8 is a typo and you didn't mean you raised your VCore that high.
