CPU frequency ISAnd I cant change FSB only I can change is CPU Frequency
CPU frequency ISFSB- or at least as close as you can get to it on AMD systems. AMD hasn't had a "true" FSB since before socket 939/K8 CPUs - that's about four years now ...
Well, there's obviously something wrong with the CMOS/BIOS. I've never seen a socket 939 board with less than 200 MHz for a clock speed (CPU frequency). You can make a board do it with the right chipset and AOD (AMD Overdrive utility) but it's not in BIOS like that - at least it shouldn't be ...
In bios overclock is auto (200) and (100). In few days i can make pics in bios but now i cant. But I assure you its stays on auto, and I did not overclocked it, Somehow it keeps overclocking after i turn on pc. And i resetted cmos few times. And theres nothing in BIOS (no function) that can auto overclock my cpu.
Nope, I dont have any overclocking software. That overclock just appeared one day and I cant get rid of it. And cuz of that almost all of my games are running unstable.. But I played COD 6 not long ago and didin't notice any glitches, except sound glitch during brief of the mission sound was disapprearing for few secs, but during some action everything was fine.
I would reset the BIOS to defaults, just to be 100% sure its not the BIOS..
Im not sure reborn20, if you issue was similar to mine.. but during overclocking my old socket 939 (4200+) after about a 10% OC my usb became unstable also.. my motherboard was locked so I couldent change the speeds.. BUT I did find a temporary fix for this issue.. its well documented on google for my mobo at the time (biostar) where overclocking would cause the system to be unstable in usb 2.0 mode.. my fix for this was continueing to overclock, but reducing usb speeds to 1.1 (also know as fullspeed sometimes on some motherboards) Im not sure if this is anywhere neer your current issue, and if it were, im not sure if it would help you any.. but thats just my two-cents
