- Aug 29, 2012
- Colorado
So I did some overclocking yesturday and got my 965BE to get to 3.9GHZ. Here is what I have done.
I first started out using the AMD OverDrive application since that is what it said to do in this>>>http://www.overclockers.com/step-guide-overclock-amd-phenom/<<<I was able to OC to 4.0GHz. Than after searching around in the motherboard application that were installed with the driver disk I discovered that the mobo had a program that would automatically set and test the processor for the most stable overclock. It states the program is only for BE processors. After running it it set the processor to 3.9GHZ (x19.5 multi and 204 FSB). Now for some reason I am not getting any temperature readings. I have tried other programs to make sure it just isn't my Core Temp program having a bug in it. NOTHING can see the temps. I am now very nervous that my fans will not work correctly because they can not see the temps and know when to speed up. I have tried restarting and resetting the multi and FSB back to factory but still no temps.
Some one please help!
