Help trying to Overclock the Asus P5P43TD Motherboard
Mr.Weston
New Member - NEED HELP OC Asus P5P43TD motherboard
I would first like to say hello. I am a new member and I Need help with overclocking my CPU in Bios
the specs for my computer are as followed:
Intel Pentium Dual-Core E6500 Wolfdale 2.93GHz 2MB L2 Cache LGA 775 65W
Dual-Core Processor
Tech Spec
Core
Wolfdale
Multi-Core
Dual-Core
Name
Operating Frequency
2.93GHz
FSB
1066MHz
L2 Cache
2MB
Manufacturing Tech
45 nm
64 bit Support
Yes
Virtualization Technology Support
Yes
Voltage
0.85V – 1.3625V
Thermal Design Power
65W
Kingston HyperX 2GB 240-Pin DDR3 SDRAM DDR3 1800 (currently running on board
at 1643mhz)
2GB
Speed DDR3 1800
Cas Latency 9
Voltage 1.7V - 1.9V
ECC No
Buffered/Registered Unbuffered
HIS H467QR1GH Radeon HD 4670 1GB 128-bit DDR3 PCI Express 2.0 x16
Chipset Manufacturer:ATI
Core Clock:750MHz
Stream Processors:320 Stream Processing Units
Effective Memory Clock:1600MHz
(which is clocked with their catalyst)
Western Digital Caviar Green WD5000CSRTL 500GB 7200 RPM 16MB Cache SATA 3.0Gb
APEVIA ATX-AQ700W-BK 700W ATX12V / EPS12V SLI Ready CrossFire Ready Power Supply
I am running Windows 7 32bit and I also tried to install the Turbo Key but it does not work on my system.
I don't know if this would help at all but if someone could inform me I would appreciate it. I heard this can get up to 3.66GHz if you up the FSB to 333 but I am looking to only go to 3.52GHz.
I hope someone could walk me through the BIOS settings so I could tweak everything correctly & ensure stability.
I have built some computers before but never had the opportunity to overclock, hopefully someone could walk me through the steps. Thanks.
Mr.Weston
Hi!
There is no need at this point to give you individual specific instructions, there are several basic guides here:
http://www.overclockers.com/forums/showthread.php?t=645416
You can also serch the net for Core 2 Duo OC guids..there are TONS of them! the more you read up front, the better off you will be when it comes time to get your hands dirty.
However..if you are having trouble understanding anything in them, or your not having luck with them, then be sure to post again.
The second link in particular applies to you, but you might want to browse the first link also.
I also might suggest trying to use the ASUS OC software your first time out, since it's fairly easy to use, and will help you get familiar with things. It should be on a CD that came with your board, or you can download the latest version form ASUS.
The good part is, if a setting doesn't work, you just simply reboot and it should restart. If you change the settings in the bios, sometimes it will freeze up and requires you to reset the bios (Using a jumper on the motherboard) to start to get the PC up and running again.
Once you get comfortable with the software, and find out whats stable for your PC, then I would venture into the bios and make the settings permanent.
