As suggested, I read the white papers on OC, WOW! I think I'm a bit out of my element here, however there is some good news. After reading I dove into my BIOS, all of my CPU and memory options were greyed out unless I selected Jumperless configuration, in there to my surprise, under CPU settings was an automated feature called, of course, Overclocking, I could select 3%, 5%, and lastly 7% OC. On the right hand side of the BIOS screen in this menu it said "Based on my selection, "all relavent system parameters will be automatically adjusted", and they were! In CPU-Z my clock speed went up to 3.65 from stock 3.4. My multiplyer is at 17, Bus speed increased from 200 to 215, HT link from 1000 to 1071, DRAM frquency up from 666 to 715, NB frequency from 2000 to 2141. Most surprising is my CPU voltage went DOWN from 1.54 to 1.44! Also, my CPU is running cooler, from a resting temp of 37c to 34c! how can this be explained? My only problem, and it's not huge, is my GPU temp increased by 5c to 49c from 44c?? Anyway I really wanted to hit 3.8/Mgz but attempting everything I learned from the white papers, the ASUS MB would not let me manually adjust anything in CPU or Memory, it always gave a selection on the right hand side of the screen and all roads when calculated led to 3.65. This was an easy OC, but how to get to 3.8??
Thanks to all and sorry for being so verbose.
Rpg
