- Jul 22, 2010
I just hooked up this monitor, I'm running a GTX 980, driver 353.06, under device manager I'm getting a generic pnp monitor, is this normal? When I try to run the disc for the monitor (Nvidia driver 331.82 that is on the Asus disc) I get a message stating "This graphics driver cannot find compatible graphics hardware"
Only reason I pursued this is with YouTube at full screen on 1080, the motion is a little choppy when panning. I have everything set at 144Hz but not sure If this is normal. I want to be sure I have it set up correctly.
All help appreciated.
Edited to add, I'm not using Lightboost (yet) so if this is what I need then what settings are recommended? I'm also using the DVI cable.
Thanks
Thanks
