- Thread Starter
- #41
I have gone back and re-read the entire 2 pages of threads. I was looking for the mobo police. I really did not find them on the scene. ...
Gonna weight in here....My wife's rig is has the same mobo with a FX 6300, Thermaltake water 2.0 Performer, same case with front bottom and 1 top 120mm fan. Running F@H with cpu at full 100% on all cores only hits around 34C.
My sig rig again same mobo, FX6300, with Asetek 240 water cooling, in a Cooler Master HAF X with max fans. Under F@H at 100% cpu(all core) and 100% on gpu (EVGA GTX 650 2gb) sits right at 33C.
In both cases the CPUs are at stock running 4.0Mhz and ambient room temp of 28C.
Awesome 'weigh-in'. Now not what you have but how you have your same motherboard setup to run. Maybe how your wife's rig is setup in bios to run. That is the how that "Denii3D" needs to know. Now that would be a whale of a weigh-in with particular voltages and other pertinent settings.
RGone...
Only changes to either rig's bios was to set the ram speed and timings. Everything else is still at stock settings.
the 6300 turbo takes them up to 4.1. only change I made was in Windows power setting to high performance.
After I read what you said about only changing timiings related to the ram, I figured you were using TuboCore which will only clock 3 of the 6 cores to 4.0Ghz or so. That is not the same as what most want to do with an overclock. Or how they wind-up doing it with most tutorials since they disable TurboCore and adjust the mutliplier upward and run with all cores on at whatever speed they can overclock up to. You are using the FX-6300 as AMD designed it to run but not how most overclock. I expect you can do what your are doing with that motherboard and experience the temps you are seeing. But I doubt you will have such results with the multiplier locked to a speed of 4.0ghz and all the cores on at the same time. Happy computering.
RGone...
Yes, I am fully aware that turbo core is not the same as making changes in bios. You say that turbo core only clocks 3 of the 6 cores. Interesting since core temp shows ALL 6 a 4.0Mhz not just 3 (see attached pic) I've been showing that core speed 24/7 while folding. So, is it a proper OC? No. But it's still OC'ed from stock and not just for a few minutes here or there. The point I was trying to make is this...If turbo core can boost clock speed to 4Mhz 24/7 stable then changes in bios should be about to also.
Don't get me wrong, I know you guys have more experience than me. And, I respect your opinions and advice.
Perhaps AMD themselves are wrong. They say TurboCore will only clock up the full multiplier when 3 of the 6 cores are not under full load.
There is 2 levels of turbo now.
EXAMPLE
FX-6100 (3.3ghz)
level 1 : All 6 cores oc to 3.6ghz.
level 2 : Only 3 cores oc to 3.9ghz.
That is how AMD describes TuboCore for that cpu. What you have is unknown to me based on what AMD says. Maybe it is a board thing, which I will never experience since I will not have that board or its options. I think you can consider yourself lucky since I have not heard of TurboCore pushing ALL the cores to their max overclock nor does AMD say such is possible.
RGone...
