- Jul 12, 2002
micamica1217 said:
the bd7II is nice but the p4pe has better voltage options and better temp readings....at $124 for a non-raid, non S-ATA it's a steal.
the max 2 2edition is also a great board, yet as you said, price is a factor.
there is just no reason not to go with a "PE" chipset mobo today.
GB might be just around the corner, yet I too have to watch my budget. (paying almost $75 more for just a little extra bandwith )
mica
Yes, there is not doubt temps read high and voltages read low on the BD7-II. But once you understand the temp is inflated by 5C and the voltage will read 1/2V low on the 12V it is a very effective board.
I considered the P4PE, but I could not justify 50% more just to get a 4:5 multipler. This is the only reason to consider PE boards, which the P4PE is one of. But as you said, putting big money into a PE board is probably not wise. If your ram is good screaming cheap boards like the BD7-II will provide clear improvements in fsb capablity over his current SiS for less than 90 bucks.
