- May 5, 2009
- Oregon, USA
I think you are correct i have done some research and i think its best to let go the colored coolant and just get red colored tubing, so i have removed the colored coolant from the cart & decided to go with Distilled water itself.
Should i get silver foil then? Its available on frozencpu for about $7 and drop it in the RES?
Yes get the silver coil. You can place it in the res or inside tubing.
Check build logs to make sure exactly where it will fit. There is risk you can bump into your video card or you may want to mount it directly onto your 35x pumpReplaced the 250 RES with a 150 as advised to me
Are you referring to this radiator here
Yes that radiator is only 30 mm if you need it that thin but tests better than the GT Stealth with medium-speed fans.
I think any 120.3 radiator mounts very easily inside the case on top, though i am not sure yet if i want to mount it on top again adding to the heat inside the case, or mount it outside the case? If i decide to go with inside mount would i need to get those mount brackets which are listed below on the site as optional?
How about the Black Ice GTX Xtreme 360, i read its one of the best when comes to Heat Dissipation?
The radiator hangs easily (at least from four corners - you may have to drill a couple holes, which you will learn when you read the build-logs) but if you buy one too thick, you have to put the fans on top and then you won't have those red Bitfenix on top, which is what you want isn't it? You really need to read some build logs because the HAF X case is a bit strange with the limited room up top. Many remove the top 200 mm fans and discard them so they can get fans above and below the radiator. So figure out in advance what you seek. This is why I was concerned about moving too fast. Do we know your heat load yet?
About the fan controller, i choose this since it has the most Wattage per channel that i could find and i want to connect my CCFL's to 2 off the channels, do you think its a good idea?
I have not put lighting on a fan controller. You will want to make sure you don't over-load any circuits and that your lighting will respond. True fluorescent lighting usually doesn't work with typical voltage dimmer switches but not sure about the CCFL.
I recommend 3/8" ID & 5/8" OD tubing for you. All compressions must be exactly that size. As Conumdrum says 1/8" wall tubing will kink less than 1/16". Since the tubing has two sides when you look at it from the top, you need to get the 3/8" ID & 5/8" OD tubing to get 1/8" wall thickness all around. It's a common size so you should be able to find red.Thanks for pointing this out i have taken a note off this now
Moving on, i have read quiet a few guides about tubing sizes and how bigger ID is not really always better. However what size tubing & What brand tubing you guys would recommend getting? Is 1/2 ID 5/8 OD a good size to get. I was thinking of red color tubing preferable if i get blood red even better....
Your CPU block has 4 ports but you are only going to use the Primary Inlet and Outlet. If you put size X in the primary ports then you will only be able to use size Y in the secondary ports. See the Swiftech website for more detail but your fitting will be compatibles1)Another thing i dont understand is, my CPU block compatibility chart says:
" Primary Inlet/Outlet-With 3/4" Tube OD fittings
Secondary Outlets-Max 3/8" tube OD fittings
Primary Intlet/Outlet-With 5/8" Tube OD fittings
Secondary Outlets-Max 1/2" Tube OD fittings "
Can someone pls explain me if my standard compression fitting that i get (1/2ID x 5/8OD ) would be compatible without any extra attachments?
You can but it is not necessary and may create more complexity for someone learning about fittings. It's your call. Will it be more fun or more headache?2) Can i add a flow indicator? Or will it just hamper/slow the flow of water?
Loop order is fine.3) Started doing some homework now, drew up a few possible loop setups, and i think the best to do would be RES >> Pump >> RAD>> CPU >> GPU>> RES. This would significantly reduce the length of piping required! - Your comments pls.
4) Another prb i just realized is there isint any red tubing available for the 1/2 ID x 5/8 OD
Its only available in 1/2 ID x 3/4 OD.
Get a 10' pack of the Danger Den Dreamflex and a 10' pack of the Primochill Primoflex is my recommendation. The reds may look a little different and you may prefer one over the other. Plus you will use up 20' of tubing over the next few years if any of it fails or wears out and you wish you change. Tubing shipping is expensive so I commonly get 10' to 20' to save shipping. It's up to you. Look at the colors and see what you like. Each will work well.
Will return later today. Let's try and get the tubing size and fittings straightened out. Then go through the beginning guide and make sure we have covered it all. We still need to talk heat load and cooling and relation to fans.
Please note that I am only sharing my opinions. If they differ than others, then we can talk it out. But it does not diminish anyone's opinions already stated. We can all water-cool. Good luck.
