- Jul 11, 2011
I installed a hyper 212 cooler on my new rig.
It works normally, when heats up the fan goes faster etc.
I'm not sure if the fan is just silent but I can't hear it change speeds.
Thats not my problem though.
Problem:
I've tried using Speedfan and AMD OverDrive to change my fans speeds and none seem to change its speed at all. It stays at the normal speed (cpu temp speed).
I think my mobo is the problem. Not sure if i have to change bios settings
Specs: (NOTHING IS OC'd)
GIGABYTE GA-MA785G-UD3H
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 125W
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066
AMD Sapphire 6970
Problem:
AMD Sapphire 6970
