- Jul 7, 2013
Okay so I'm sure some of you have heard that in Windows 8 you have to disable HyperV to get VB to support 64 bit OS installation, on top of having your CPU virtualization setting turned on. Well, I am on Windows 10, and sure enough, it's only listing 32 bit OSes. So my question is how do you fix this in Windows 10? As far as i can tell HyperV isn't in Windows 10 so now what's the problem?
