- Jan 13, 2005
OK so long story short I started a new job with a non profit that need quite a bit of help and some optimizations to minimize down time.
They have quite a infrastructure built up out of literal scraps from other organizations. They have all their bulk licensing in order and plenty of keys to go around but the hardware aspect is a constant rotation.
as an example most of the systems are Dell Pentium 4 OptiPlex towers or older systems that were used extensively before they got them.
I organized the storage room and dumped a lot of systems that were just too old for their standards or didn't pass visual inspection (bulging caps, missing components, scorch marks) I got it down to about 20 or so decent looking systems Pentium D or Core 2 Duo's and newer of various makes/models
That's the background.
I need a some info on creating slipstream installs of windows 7 and 10 both Pro that will be up to date and also have Office 2016 programs installed aswell. They have a bulk license for Office 365 ProPlus but I need the local applications on there with the install in order to really save some time.
i remember how to do the windows 7 updates in a slip stream from my personal experience but I am at a loss on how to do it with Win10 or to get Office 365 Pro/2016 on a 7/10 slipstream.
that's the bulk of what I need help with, the other less important part would be having some settings pre set when its installed like with fancy themes turned off performance options set to make things run faster as opposed to looking fancier that sort of thing. Aero really kills the performance of these things and some times its a chore to turn it off just to get the system going.
any tips, hints, walkthroughs or good apps you guy could recommend would be a huge help
