Hey guys. I'm running a 2x8 DDR3 G-Skill overclocked to 2133MHz at CL12 timings (XMP is 1600MHz CL9). I've read that configuring your Pagefile to be about the same size as your RAM helps performance, so I've done so (Running Win10).
1. Is that true? Should I reduce the PF size? It's currently at 16GB.
2. MSI Afterburner has the ability to monitor pagefile usage... and I noticed my Pagefile usage is higher than my RAM usage. Is that normal? Why should the PC use the pagefile if it didn't use all the RAM (it didn't even come close)? Here's what the Afterburner shows (Notice current usage and Max):
Would love some insight! Thanks!
