- Dec 2, 2003
Ok well im going to home depot sometime and i need to pick up some stuff
Right now i need some more renforced dremel cut off discs, metal drill bits (that can go through metal, steel that is), acrylic and some screw things o and mesh.
What are these screw things that are holding the window called?
they like just go into the hole, and you put a nut around it on the inside of the case i guess, whats it called? does home depot sell em?
And do they have the molding for windows?
http://xoxide.com/thickmolding.html
like that stuff or whatever?
and what size drill bits do i need for those screw things for the window?
do they sell any handles that i can use on my case?
thanx
btw they DO sell acrylic there right? how big are the sheets?
edit: i also need mesh!! like the cool mesh like the mesh on the bottom of the case in this pic
does home depot sell all that? how much would all that be?
thanx
