- Dec 29, 2011
- Thread Starter
- #41
That's quite a price and performance spread, did you mean 6950?
6850 ~$120
560 ~$160
6950 1GB ~$200
560Ti ~$210
Give or take 10 bucks either way. 560Ti or 6950 will outperform a single 6850 by quite a bit.
Not to confuse you even further, but what Bobnova said is very correct. The bang for the buck of a dual 6850 setup is stellar as long as you're not planning on running more than 1920x1080 due to 1GB frame buffer. And they overclock like sprayed roaches. 580-level performance for little over 200 bucks. Same can be said for GTX460s. Big price drop probably in the near future for existing AMD cards due to 7xxx coming out.
I've been pouring over hardware so hard that I made a mistake on the prices. I was thinking that the 560 was $130 and the 560ti was $160 when I was actually looking at the 550ti for $130 and the 560 non-ti for $160. Yeah, I don't really want to spend $200 on a GPU so I'll be looking at either a 6850 or a non-ti GTX 560.
