you could use CCleaner that as a reg clean option and it can delete loads of old reg places
it also lets you restore the reg also
EDIT and backup it also (do before doing anything crazy!!)
Personally I don't trust any third-party registry cleaning programs, especially from unknown sources, for determining that my registry has errors that need to be repaired or deleted. If you were to do a registry scan w/ ten different so-called registry cleaning / repair programs, you'd get ten different scan results. So being that the results would be different based on the program, which one would you trust to clean your registry?
A guy posted here some time ago that used the built-in registry cleaner in CCleaner, after which on reboot Windows refused to load either to normal mode or safe mode. He hadn't made a backup beforehand, and had important data on the drive that he couldn't afford to lose.
A fresh reinstall of Winderz instead of playing reindeer games with registry cleaners/snake oil?Now what can clean windows registry like a good vacuum cleaner, but not eat up the carpet?
