- Jan 6, 2004
- South Dakota
I have a Lian Li PC65B with:
1 - 80mm exhaust
Fortron PSU w/ 2 80mm in a straight line array
1 - 80mm blowhole
2 - 80mm intakes
1 - Zalman 70mm fan @ 12V on GPU cooler
CPU:
Thermalright SP-94 (lapped to 1500 grit)
92mm Tornado @ 7V
Temps Idle:
Case - 25C- 27C
CPU - 36C - 37C
Sensor 3 (think it is N/B) - 27C - 28C
Temps Load:
Case - 30C- 32C
CPU - 46C - 48C (side panel off - 40C - 42C)
I have a panaflow H1A and a vantec 92mm stealth. Is there anywhere that I can incorperate these to my benefit? I have the panaflow strapped onto the 20pin ATX right in front on the 5.25" drive bays, but I don't think it's doing anything there...
This is what the case looks like... Case
thanks
P.S. The fan grills ARE cut out, and ALL the cables are sleeved and routed nicely. The HDD is in the bottom cage closest to the windowed side.
1 - 80mm exhaust
1 - 80mm blowhole
2 - 80mm intakes
CPU:
92mm Tornado @ 7V
Temps Idle:
Case - 25C- 27C
CPU - 36C - 37C
Temps Load:
Case - 30C- 32C
thanks
