BillA said:
how so ?
if a tee or reservoir has a sealed top - ?
and a 'fill and bleed kit' is also sealed once filled
I am assuming people are capping their T's. Maybe that's a faulty assumption, but I really hope its not.
Given the capped line/sealed fill 'n bleed, I would consider these loops 'closed', hence post #8.
If we are refering to absolutes, then they(tline, FnB's) are not, infact, closed, where as a heatpipe is(should) be tightly sealed shut.
HiProfile said:
Unless what I learned about humidity was wrong, it'd only evaporate to a point and more or less stop. Once the air inside the reserator gets around 100% humidity, the water vapor will start condensing, thus cycling the water back into the system.
Your understanding of humidity is not wrong. But there should be no air in your reserator, and ther should't be enough heat to evaporate anything (if its all set up correctly) You are describing a heatpipe, which requires a lot less fluid(or one with a lower specific heat).
HiProfile said:
Loosing water through a metal-to-vinyl seal will be negligible. BTW in laymans terms, a closed loop is one where the water doesn't directly contact the outside air. If we're going to start nit-picking around here, we'd have start a minimum wording per post so that people explain themselves as to not get flamed for saying words that generalize like "liquid" or "mixture".
I agree, however I would like to see some more care given to word choice (even though I am as guilty as anyone, sometimes.)
zip22 said:
the reserator is sealed at the top, isnt it?
Looking at the
pics, I believe it is. Except for what appears to be a pinhole in the center of it. (BillA: is this what you meant by the reserator not being a closed loop?)
