Apply a thin bit, fill all the gaps. Use a CC card or such.
Buy another tube of MX-4, why not.
Put a blob in the middle, put in on, twist once back and forth, and put HS on tight with anal care to getting it even. Done.
Tell me about it!This is almost like surgery in here with applying thermal compound...
Wait, i dont see why you would put it somewhere that isnt a heatpipe. You want the best coating on the heatpipe, because the heatpipe transfers the heat, it should get the paste. This leaves the best thermal transfer where it needs to be and it will lower temps.
Look there is no reason to apply thermal compound to the aluminum part of the heat sink because the copper heat pipes are the only thing that helps out dissipate the majority of the heat.. So just apply 3 small lines on the copper heat pipes and then make sure that you have proper coverage like this...
Or just spread out a very thin coat and call it a day ... This is not rocket science and this way over complicated here guys for a basic thing here..
You're contradicting yourself if you take into account that people fuss about 1 to 2* difference in temps.apply thermal compound to the aluminum part of the heat sink because the copper heat pipes are the only thing that helps out dissipate the majority of the heat..
On bigger chips like the GPU you're using, I usually spread TIM on the IHS with a straight edge.
