How do you know what's wrong when you have no errors?
Tithulta
Cleveland, TN
Ok I've put together and OLD system for my sister to use as an email machine which is all she does with a puter besides surfing a bit. Well like I said it's OLD, but not stone age.
Ok here is the system specs followed by a description of the problem.
P5I430TX Titanium IB+
300 mhz amd k6/2
16 mb pc100 sdram
540 mb quantum hdd(oldest part;compaq oem part;system bought in 95)
250w atx psu
voodoo3 3000 pci
I don't remember what OS either 98 or 95
(audio not installed at this time)
This board actually has a very nice bios lots of tweaking available.
Anyrate my problem is it's not booting, it gives no errors, it gives no POST error beeps. The Hdd shows up in the cmos menu as secondary master. after the ram count it just stops booting, but doesn't freeze up as I can wait a few minutes and hit DEL to enter the bios with no problem or I just hit the DEL key right off and enter the bios. Is it a dead hard drive? I am thinking it is since I don't hear it turning. Also why would the floppy light stay on? It's brand new... it doesn't seem to be doing anything, but the light is on.
Any ideas?
Generally, the floppy LED stays on when the cable is backwards. (180 off) My old ASUS board doesn't have keyed slots for the cables, so it's easy to put them on wrong.
Yes and if the pc is set up to boot from drive a: first then it's waiting for drive a: to respond.
Ok you were right aboutt he floppy...the stupid thing actually has 2 cut out so that it IS possible to install it backwards...go figure.
Futhermore I can't make it boot at all so far. I've changed the boot device to everything listed and tried a start-up disk to no avail.
Bad Hdd? Bad pci bus? I'd liked to ahve gotten to tinker with this board some before giving it to my sister, but looks like might not happen.
You've set it to boot from drive A, and you use a boot floppy. What happens then? Does it just stop after detecting the drives?
Disconnect the hard drive and try to boot. You should get a "hard drive not found" or a "No boot device" error. If you do get one of those messages then you know that is a bad hard drive, bad hard drive controller or bad IDE cable.
If you have a CD-ROM installed, you should disconnect it as well. They can also cause this type of problem.
You may want to try changing the hd to primary master. Sounds like it could be KIA though
clearing the CMOS is always a good starting point. If you can try another harddrive, that would quickly tell if its a harddrive problem or controler problem or not. Maybe try that drive in another system.
Well I cleared CMOS and booted withoutt he Hdd connected and boot failed. Cleared CMOS again and reconnected the Hdd. It came up as Primary slave. On the underside of the hdd it has three rows of pins with one jumper.
JP11
SP- I have it on this one
DS
CS
Any idea which of these would be master? Like I said it's an OEM drive made by quantum for Compaq. It came installed on the Compaq I bought as my first computer back in 1995. I ahve an idea to try and will get back to you on how it works out. I forgot about having it installed on my system a few months ago so I could copy WIN98 cab files to it so it could install WIN98 from itself. :) maybe it thinks it's drive letter is something other than C:
At anyrate thanks for all the help and responses. next tiem I think I'll just get my sis to cough up some money for some new parts. :D
hmm CS is cable select..
it should say MA, and SL.. for the others...
is there no diagram included on the drive?
there is, but it's crazy... let me grab a screen shot of it(hope it's legible). otherwise I'll edit this and try to spell it out.
Let me explain more:
The "jumper configuration table" on the right has 5 options (1-5), there are 5 corisponding columns in the table on the left.
I do not remember what DSP or DASP are exactly, but I am pretty sure it is the "large drive" or "dumb" mode for when your BIOS will not handle a 10GB drive, but will handle 5 2GB virtual drives. Don't worry about it, I don't think you need it
The 5 options are:
1=slave=no jumpers
2=slave(dumb mode)= jumper on SP
3=default/master=jumper on DS
4=master(dumb mode)=jumpers on DS and SP
5=cable select=Jumper on CS, do not put one on SP
thanks
now I get Disk error insert system disk to continue etc
I tried each bootable drive letter and all did this.
So i put in a boot disk and booted to DOS
I'm running a DOS scandisk right now
There is no cdrom on this system yet as I'm broke and it's my sisters puter im building so I figure if she wants one she can give me the money to buy it.
No sound is installed ...yet
I can install a network card on it and try transfereing win98 cab files...
So opinions now...is the problem the drive, the ide bus or the ide cable. or any one of the 3....I think i have some spare cables laying around.
found the problem....blank hard drive....well sort of it doesn't ahve an OS on it. it does have some files on it I typically install to add in booting up for OS install....guess I need that cdrom now...unless you know how to get a NIC card to work without windows :D
Rather than try to get a nic to work with drivers on a floppy you might be better off to borrow the CD-ROM from your computer, load the OS and then put the CD-ROM back.
I actually do know how to make a NIC work off of a floppy, but it is tricky and not worth it.
