You can find old 462 coolers, I collected some for fun, Thermalright SLK 800 and 900 copper heatsinks, a couple of the jet engine look, Volcano and Dream.
Even a Big Typhoon.
IF I remember my research the Zalman 7000A or B comes with 462 Mounting, though not the easiest. There are all copper and copper/aluminum versions. The Cu/Al is preferred for its lighter weight. Probably that "last/best" 462 Heatsink for 462.
Never saw the Swiftech before, looks workable.
The most dramatic improvement for most of these coolers seems to involves air flow.
Neither cases nor the fans mounted on coolers in the "old" seem intended for serious cooling.
Many old "high performance" fans are loud without acomplishing all I would like.
For AM3 Heatpipe coolers I often replace the 70mm fans with either 92mm or an 80 to 120mm adapter and 120mm fan
Any decent modern fan ( I use Arctic F9 or F12 PWM) should do very well on that heatsink. Just do not go too far, air moring too far does not seem to help.
Larger slower is best. Though 80mm are usually larger, the changes!!!
