I am almost finished with my basement and am ready to start putting together a HTPC. This will be used only for media playback. YouTube, facebook vids and .mkv filkes in 1080P format. I will also like to use ti to playback 3D blu ray discs all on a 50 - 60 inch LED LCD HDTV.
My question is..is the 275 watt psu that comes with the case enough to run the rest of the components. I will most likely undervolt the APU.
Sorry, I don't know how to share a shopping cart online
P.S. I will be using a 500GB 7200 rpm 3.5 inch SATA HDD that I have laying around
Cart Item List:
nMEDIAPC ZE-C268 Black Panel 3.5" All-in-one USB Card Reader with USB 3.0 Port
nMEDIAPC ZE-C268 All-in-one USB Card Reader with USB 3.0 Port
Item #:N82E16820132029
Return Policy: Standard Return Policy
$16.99
________________________________________________________________
Crucial Ballistix sport 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 Desktop Memory Model BL2KIT25664BA160A
Item #:N82E16820148419
Return Policy: Memory Standard Return Policy
$26.99
$23.99
_________________________________________________________________
LITE-ON Black 12X Blu-ray Burner with Blu Ray 3D Feature SATA IHBS112-04
Item #:N82E16827106369
$78.99
APEX DM-317-A Black/ Silver Steel Micro ATX Media Center / Slim HTPC Computer Case w/ ATX12V Flex 275W Power Supply
APEX Black/ Silver DM-317-A MicroATX Slim Case
Item #:N82E16811154061
$44.99
GIGABYTE GA-A75M-D2H FM1 AMD A75 (Hudson D3) SATA 6Gb/s USB 3.0 HDMI Micro ATX AMD Motherboard
GIGABYTE GA-A75M-D2H Micro ATX AMD Motherboard
Item #: N82E16813128517
AMD A6-3650 Llano 2.6GHz Socket FM1 100W Quad-Core Desktop APU (CPU + GPU) with DirectX 11 Graphic AMD Radeon HD 6530D AD3650WNGXBOX
AMD A6-3650 2.6GHz Socket FM1 Quad-Core Desktop APU (CPU + GPU) with DirectX 11 Graphic
Item #: N82E16819103943
Return Policy: CPU Replacement Only Return Policy
Grand Total: $331.94
Cart Item List:
$16.99
$26.99
$23.99
$78.99
$44.99
