You can't break 20 with a 920? Is that thing a C0 or a D0? If it's a D0, you should be all over some boints. I had a brief run in with a 920 and put it under Dice. That chip still has my 5 highest point submissions on Hwbot. I milked the HW points out of that chip.
Heck yeah! You're almost there. If you can get that chip to 4500 or so, (and I see you're on H2O) then you should be in some low-level points and you'll be in!
stupid motherboard craps out at 214BCLK.
Looking for a heatsink for a Gene II mobo i picked up. It came without the PWM/NB cooler lol. Once i get that working ill see what that mobo can max out at
also picked up a AMD 60 FX Cpu. Hopefully i can get some points with that too
Looks good overall, for some reason you didn't get any points for the submission. Maybe they have a bug on their site right now.
Those cards should definitely be able to clock better than 1000mhz, likely to around 1200 would be a good goal and get you some solid increase in points.
try using MSI afterburner and see if unlocks the voltage on your cards
POINTS EARNED
League points: 16.3 in Enthusiast League
Team Power Points: 31.7 earned for the team (GTPP and: HTPP)
Worldrecord: 0 earned with world records
Global: 9.9 earned in benchmark rankings
Hardware: 6.4 earned in hardware rankings
competition: 0 earned in competitions
Total Points: 16.3 points in total
