Did you start early today?
DISKPART> format fs=ntfs label=(name) quick
The only difference between it and formatting is that formatting completes the process. I have linked above what it does and that is to simply remove the partitions. When you use the clean all, it then zeros out the drive/secure erases it.The clean command however removes formatting and leaves your drive in a preformat state... I think.
Not sure you did anything???and I have edited the information, please reread it and comment
The first steps are to open start, open file explorer, and type run in the search pane.
In win ten I had to scroll about 3/4 way down the page to find it, I used the highlighted one.
In win 7 it shows right at the top of the results.
Just double click it and it opens a thingy on your screen.
In win ten I had to scroll about 3/4 way down the page to find DISKPART, I used the highlighted one.
I guess what I am getting at is what is this doing that is different from a format? A format seems to be the 'complete circle' of this process, no? Meaning it wipes out at partitions and boot records (as clean does), THEN (what clean doesn't do) makes the drive in a useable state.
It is usually, but I seem to have a high rate of disks that can only be formatted through disk part (USB sticks mainly). I will get a dialogue about Windows being unable to complete the format and then Ill move on to diskpart. And as I said at times I want a file format that isnt listed in the Windows formatting tool (Fat32 ,for instance, is just not there sometimes). TBH the Windows format tool fails on me fairly frequently, but I can see that it would be the long way around if you dont have as many problems with it as I do.This process is seemingly more easily done in Windows with a couple of clicks versus this command line method. Right now, this is a long way to complete half of a drive format.
Good to know there are other reasons to use DISKPART, for other file formats, but that isn't what is going on here.It is usually, but I seem to have a high rate of disks that can only be formatted through disk part (USB sticks mainly). I will get a dialogue about Windows being unable to complete the format and then Ill move on to diskpart. And as I said at times I want a file format that isnt listed in the Windows formatting tool (Fat32 ,for instance, is just not there sometimes). TBH the Windows format tool fails on me fairly frequently, but I can see that it would be the long way around if you dont have as many problems with it as I do.
