*grabs lightly modded 342 and measuring tape*
the core area is right at 9 3/8" long x 6 1/8"
overall dimensions with the tanks - length 11 1/8" x 6 1/8"
for comparison:
Fedco 2-199 (aka '77 b'ville w/o ac):
the core area is 9 3/8" x 6 1/16" (an odd core I suppose - it is a bit smaller than usual)
overall: 10 3/4" x 6 1/16"
Fedco 2-302 ('77 b'ville w/ac):
core area: 10 3/4" x 5 5/8" x 2"
overall: 12 1/2" x 5 5/8" x 2"
hmmm...both of the first 2 (the 342 and the 199) are a tiny bit smaller than the last ones I had of the same models. normal minor variations I suppose - none of these suckers are cranked out on NASA spec'd equipment...interestingly, the 302 is right on the money.
measure closely before cutting anything.
note on pumps - my personal preference is the old design of the rainbow lifeguard quiet one. it is rated at 1140gph @ 0' head. It uses an isolated wet rotor design which helps tame down any heat dumping and it is very quiet. if you can find one, they are normally in the $100 range (and worth every penny).
Osirus said:
Weapon - I am using the Danger Den MAZE4 nvidia block. is there any real differnce in making a dual HC setup, over the setup I have now? Rig is in Sig.
Sorry for my confusion, but Parrellel and Series are kinda confusing to me, can you explain? I think I know what is what, but I want to make sure.
serial HCs would be like this:
res -> pump-> core #1 -> core #2 -> CPU -> GPU -> back to res
or:
res -> pump -> core#1 -> CPU -> core #2 -> GPU -> back to res
or
basically any variation that has the loop moving flow in one direction down a single tube that runs from one component to the next component.
a parallel core setup is different in that in one section of the loop, you have 2 lanes of water traffic so to speak.
res -> pump -> 1st wye fitting (flow splitter) -> [one tube to inlet of HC#1, one tube to inlet of HC#2] -> [outlet tube from HC#1, outlet tube from HC#2] -> wye fitting #2 [back to a single tube now]-> cpu -> gpu -> back to res.
at the 1st wye fitting, the tubing splits and you go from one 1/2" ID tubing (or whatever size you are using) to two 1/2" ID tubes. Each of those tubes carries waterflow to the inlet of either of the 2 heatercores - water passes thru the cores and exits through the outlet fittings of either core then thru a short section of tubing where it meets another wye fitting that merges the 2 tubes (from the outlets of the cores) back into a single tube that then hops thru the rest of the components in the loop.
basically, with serial HCs you have to push all the water thru both cores in single file whereas with parallel, you split the flow and 1/2 the water moves thru either core at that section in the loop (hence, less flow resistance)
a pic would have made that a lot easier to understand I suppose...
