Pics of my single pass mod
This is the 2-302 modded to single pass. the threaded insert started out at a 3/8 female to 1/2 male pipe adapter. I could have used a lathe on it, but wanted to use tools that everyone might be able to use. So I found a bolt that fit inside it and chucked it up in a drill. Using the drill to spin it I ground the theads off using a 4 inch grinder with a non-ferious wheel. Checking it after grinding it, it came out within .002-.003 of an inch of being round...good enough for what I was going to do with it. Then I cut of the end of it right at the end of the female threads. The OD came out at about .710 of an inch, or 23/32. I then drilled a 23/32 hole in some scrap angle to use as a guide for the trusty Dermel. Drill a small hole in the center of the core (don't push to hard as the soft copper will bend) and use the guide it open the hole up to 23/32.
Then, put the insert in and solder as Weapon instructs in this thread....filling with water, using wet towels...etc
Also, some people have asked what the core looks like where the water passes thru...you can see this in "corepic4"
