If it's for the Forum, and you can still log in, go to the Settings link in the upper right of the page.
Is it for Windows? If so then do the following:
1. Boot from install dvd, goto Repair Your Computer.
2. Click on Command Prompt.
3. At the X:Sources> type "MOVE c:\Windows\System32\Utilman.exe C:\Windows\System32\Utilman.exe.bak"
4. Copy C:\Windows\System32\Cmd.exe c:\Windows\System32\Utilman.exe
5. Reboot or type Exit.
6. After the PC boots, click on the Ease of access icon in the lower left of the screen.
7. Type in "net user administrator *".
8. Enter new password, then confirm password.
9. Repeat setp 1 and 2
10. Now type del c:\Windows\System32\Utilman.exe
11. Move C:\Windows\System32\Utilman.exe.bak C:\Windows\System32\Utilman.exe
(the above works on Win 7 and up, also only if your not part of a domain)
OR if you don't have the install dvd.
Boot in to safe mode with command prompt then:
