R Runereaver New Member Joined Sep 21, 2012 Sep 21, 2012 #1 Hello guys, I am new here. I need some help I cant figure the best setup for my fans on my desktop Note that : I have 2 fans on side 1 fan from back 2 fans from front "2 fans from top optional i will make holes for it " Thank you
Conumdrum Member Joined Sep 15, 2007 Location Small town Emlenton, PA Sep 21, 2012 #2 Front to back, side fans in. Most common for good reason.
OP R Runereaver New Member Joined Sep 21, 2012 Sep 21, 2012 Thread Starter #3 Conumdrum said: Front to back, side fans in. Most common for good reason. Click to expand... Thanks for your answer But may I ask why did you chose this setup ?
Knufire Senior Member Joined Feb 17, 2010 Location Manassas, VA Sep 21, 2012 #4 Front, bottom, side are intake, back and top are exhaust. There's no real "choosing" about this setup, this is how the ATX spec was designed.
OP R Runereaver New Member Joined Sep 21, 2012 Sep 21, 2012 Thread Starter #5 Knufire said: Front, bottom, side are intake, back and top are exhaust. There's no real "choosing" about this setup, this is how the ATX spec was designed. Click to expand... Thanks , I will adjust them today .
