Hello, looking to my graphic card I was thinking it should be possible to connect (with an adaptation) the watercooling tubes to the tubes of the cooler of the card.
To make water pass inside the aircooling tubes and give it an additional cool.
Thinking about it later, I thought, the best system to do this would be, making a hole through the plate that's directly on the gpu. And attach to it the watertubes, in the way that the water goes directly where is the hottest place.
Here a picture just to show you where the watertubes should connect to the plate
Uploaded with ImageShack.us
A system like this cud be created by the user on some actual air cooled cards, depends on the thickness of the plate.
And shouldn't be too expensive to add in factory.
So the card that has this system in factory should just have on the side two points where to attach the watertubes. Inside the tubes go through the plate.
In this way if an user has not watercooling in the system, fine, he leave it as it is, and it will cool with the fan.
If he has a watersystem, for example to cool the cpu, he can attach the tubes to the card, to keep it 20 degree cooler.
Have you ever thought about something like this?
If somebody has time and will and the means to do it it would be nice to make an experiment. The problem I see, is in making the hole through the plate, as just looking at it we don't know how it is inside, so something cud go wrong and the plate be damaged.
What do you think about it? would it be a good hybrid system?
