- Jun 16, 2014
Hey guys, anyone who can help me solve this would have a big thank you:
I recently got a new 4930k, I already had a coolermaster hyper evo 212.
My motherboard is Gigabyte x79 -ud3.
Everything is compatible with each other, and it seems people have placed the heatsink on the cpu just fine, however, everytime I do this the heatsink seems to wobble a little back and forth.
If it wobbles side to side, I have no problem with that, but it's wobbling away from the processor which is definitely not fine. If anyone has a hyper evo 212 and a LGA 2011 motherboard: the screws don't seem to go in enough for the bracket to hold down the heatsink firmly on the cpu. No matter how many times I take it out and put it in again, there's a very small amount of space left between the top of the cpu and the heatsink.
What this does is causes the temperatures to be ~50 degrees at idle. I can press slightly on the top part of my heatsink and hold it in that position to cause the temperatures to drop by ~15 degrees.
I've tried taking the whole heatsink out and screwing it back in over 15 times. People have installed the cpu in the past with the same build, so I'm really not sure what the issue is here. Maybe the hyper 212 is defective as its a year old and I took it off the cpu I used to use.
Anyone ever been in the same situation? Heatsink wobbling off the cpu by just a little?
