- Feb 15, 2018
- Right here.
https://www.newegg.com/Product/Prod...VwpJbCh0lqQh_EAkYASABEgJu1_D_BwE&gclsrc=aw.ds
I have been looking for some TEC cooling solution since I had The Cooler master V12 Tec cooler.
I was wanting your opinion on this one and if you know of any that are better or will fit my Ryzen 7 because I do not know.
The spec's do not show the AMD ryzen so...
I can not find any reviews here on it and well before I go fiddling around with water again (And frying my system) I want to know if there is an alternative.
Thank you all.
Thank you all.
