Hi!
I have a weird issue. I cannot properly disable HD Audio Controller in bios on my Asus Z170 Pro Gaming.
1) I disable HD Audio Controller in bios, save and exit. All other settings are on default.
2) The screen loses signal for about 30 seconds.
3) The video signal returns and the boot proceeds as normal.
4) I press "turn off" in Windows.
5) The screen loses signal and does not come back. The fans and the lights in the PC are on but the computer is unresponsive. The PC does not turn fully off.
6) After several minutes of waiting I keep the on/off switch pressed to turn the PC off.
7) I turn the PC on, enter Bios and Switch HD Audio back on.
I have tried this with both HDMI and DVI and by enabling and disabling realtek audio in device manager. The outcome is always the same. Is the card defective? Is there something simple I could try?
