The Haswell stuff, 4670k would be the new i5. They're on socket 1150, which is most likely what the next gen will also be on.
Do you need/want the capability for Crossfire/SLI?
This is plenty for you then.
That's actually a decent set of RAM, and makes that board worth it for you.
Also, when I posted the Gigabyte, it was $115.
I think I decided to go with the 3570k but not sure what mobo to get yet, possibly this one with free 8gb memory its $350 for the upgrade
3570k
8gb 1600
ASRock Z77 Extreme4
I too would urge you not to go previous gen. The chip you want now is the 4670K. You get more performance per Mhz, and 6 sata 6gbps ports.
This is a "general hardware" question.
I don't believe your Z5500 is coax. Afaik it takes SPDIF and regular 3.5mm jack.
this is coax
definitely not what your speakers take.
If I were getting a new PC now I'd go with a Haswell i7 in your shoes. And I'd overclock it. You don't need a lot of power but it sounds like you want your system as fast as possible.
I don't personally see any reason to upgrade from your 965 if all you have is stocks and websites going.
If you really want a significant upgrade though I'd go with something like a 4770K and an ASUS Z87 PRO board. That'd be my choice. Obviously other people will recommend a different cpu/board.
