- Dec 6, 2013
- Baden, Austria
I am afraid I killed my pc. But not with what was predicted to happen. No OCing.
I had my pc running with default settings and just wanted to find a way to measure the Vcore manually with a DMM. Since my cheapo mobo does not offer an easy way I thought to measure the voltage directly on the mosfets which worked perfectly. Until the moment I accidentaly touched the middle pin (which is not connected to the mobo) while connected to another pin on the mosfet.
The pc immediately went off and I cannot switch it on again.
So I am not sure what I killed because after the incident I unpluged the 12V ATX connector to measure the voltage that comes from the PSU.
What should I expect when pc is off? Is still 12V applied to the plug coming from the psu? Because I measure 0.2V.
Chris
Chris
