marionwalters
- Apr 14, 2013
Hello everyone! As the title states I would like to build a custom router for my home. Unfortunately, I don't have much experience with networking in general and could really use some guidance and advice. Thus, why I have come to overclockers.
My main motivation for building a custom router is for increased security, to setup secure wi-fi access for our home and to learn more about networking and security in general.
Our current router is a Netgear WNR834Bv2 and is a piece of garbage for the most part. The wi-fi it offers is very poor (being in the same room, even right next to it, or a few feet away doesn't seem to matter) and is not secure. Using Reaver I was able to brute-force my way into our network very easily because the router features WPS. Although Netgear says that the WPS PIN can be disabled, it is not actually disabled.
I was interested in using PFsense as the software for the router and firewall. However, I am open to other types of software and any feedback is greatly appreciated.
Regarding the hardware I would need, I believe I would need the following components: a motherboard, a CPU, a heatsink, RAM, a HDD, a NIC, a switch, an antenna, a case of some sort, and a PSU.
Hopefully these are all the necessary components, if not please let me know. I have some hardware laying around already and I hope it can be used to save some money.
I have an AMD Athlon II 640 CPU, a Biostar A780L3G motherboard, some stock heat sinks for the CPU and some thermal paste.
Could I use these components for my custom router? If there are better alternatives that are cost effective, I would certainly be open to using a different CPU and motherboard. Perhaps a motherboard with ECC support?
I would like the router to be a dual-band, gigabit router with wi-fi support. Ideally I would like it to run on as low power consumption as possible without compromising performance.
We have four computers in our home and would thus need a minimum of four ethernet ports with room for expansion. Could I purchase a single gigabit NIC (dual port) or two single port NICs (WAN and LAN) and then use a gigabit switch to expand the number of LAN ports? If so, would this cause a bottleneck since there are multiple devices connected to the switch which is then connected to a single ethernet port on the router? I don't think there would be bottleneck as far as speed is concerned but perhaps the number of connections (games and torrents) would be less than ideal?
I am also posting our internet speed below for what it's worth:
Ping: 5ms
Download Speed: 47.00 MBps
Upload Speed: 11.18 MBps
Server <50 miles away
From Speedtest.net
I will be closely monitoring this thread and happy to provide any further information if required. I greatly appreciate all feedback and help. Thank you!
Ping: 5ms
From Speedtest.net
