not much better, i believe i can get to 4.4 around 1.27 - 1.275, but 4.5 is going to be over 1.31Oh, sounds like you do have a better one than mine then.I ordered my chip at newegg, on the release weekend (July 4th)
There was a 50$ combo with this board putting it at $300, i knew if i did not go this this platform i would have to replace my ram when i upgraded
I believe my current config is stable
43 Core;39 Cache; 1.225 vcore; 1.16 vcache; 100.0 Blck seems stable
I would think if LLC was 'on' that would mean a more steady state Vcore/Input. LLC goes AGAINST intel specifications for vDroop (its natural).
Load line (electronics)
In graphical analysis of nonlinear electronic circuits, a load line is a line drawn on the characteristic curve, a graph of the current vs the voltage in a nonlinear device like a diode or transistor.
It represents the constraint put on the voltage and current in the nonlinear device by the external circuit. https://en.wikipedia.org/wiki/Load_line_(electronics)
https://www.anandtech.com/show/2404/5Actually, load line droop (Vdroop) is an inherent part of any Intel power delivery design specification and serves an important role in maintaining system stability.
Perhaps another thread to discuss so we don't torture pq..............but it IS a natural part of how the processors work.
I'll leave the thread with this...
Edit: and yes, some boards it's simply enable or disable without different 'levels' of load line. Enable on, disable off. Simple.
Do you have the ability to adjust the Load Line Calibration except "enable" or "disable" it? Something is wrong there. You should not need a vcore of 1.3 to get an overclock of 4.4 on that CPU unless you are a big time silicon lottery loser.
