So I had my topic here but It seems got deteled. I was posting here information about my OC'ed cpu. from 3 ghz to 4 ghz, The problem is MY BIOS SETTINGS JUST RESETED FOR NO REASON. I was playing MAD MAX game and some times I got Nvidia drviers crushed. After a while I have seen FPS drop in game. I checked Cpu - z and I saw my cpu is non clocked. wtf? The problem is - I dont remember my all settings in bios.
BCLK 201
PCEI 100
UCLK 3224
API l8nk 7254
Extreme phase power moder mode auto
CPU voltage - ???
Cpu pll voltage 1.88
qpu /dram 1.28125
Dram core voltage 1.64
cpu apmlitude 800 mv.
Can you tell me if they are ok? and what should be my core voltage. 1.3 for stable 4 ghz? Is it possible to get more than 4 ghz and be stable? plz help me. I need fast advices.
MY PC:
Mother board Asus P6X58D-E
RAM : HyperX Savage 12 gb ddr3 1600 mhz CL 9 ( DO i need manually set my all CL's in bios?)
CPU : i7 950 3,07 ghz.
Corrsair TX 650W
Cooler is : Grandis Xe1236 v2
EDIT; I adding screens from bios. it will be easier for you to tell me what to change.
BCLK 201
PCEI 100
UCLK 3224
API l8nk 7254
CPU voltage - ???
qpu /dram 1.28125
MY PC:
Corrsair TX 650W
